 | November 4, 2009 By:Eric Tabb
In our last installment, the 380 motor was back from getting the crank rebuilt and the cylinder porting cleaned up. Now it's time for the bottom end.
 | September 22, 2009
By:Eric Tabb
Having ridden a 2002 model bike with stock 43mm forks we can say that we think something was probably done to our forks because the stock 2002 forks had a near deadly mid-stroke harshness that our forks didn't exhibit at all.
 | August 24, 2009 By:Eric Tabb
Our main objective was to rebuild both the top and bottom end to ensure our 380 engine has a long life. In addition we kept a keen eye out for anything else suspect that needed attention and ordered replacement parts where needed, such as the kick-start pawl spring. We also made a few performance modifications to spruce up mighty 380 a little bit yet not go over-board.
 | March 18, 2009 By:Eric Tabb
When a bike is left to sit for extended periods of time the seals can dry out and become brittle and prone to leaking.
 | February 23, 2009 By:Eric Tabb
Another area of a used bike to check thoroughly is that of the chassis and other attached parts. This includes things like suspension, swingarm and steering head bearings as well as a general inspection of the frame and swingarm for cracks or extreme wear.
 | January 15, 2009 By:Eric Tabb
To find out the current condition of the motor we decided a top-end teardown was in order. This will allow us to find out firsthand the condition of the head, cylinder and piston as well as giving us a good feel for the overall condition of the motor.
 | December 8, 2008 By:Eric Tabb
While the four-stroke can put the power to the ground effectively there is nothing quite like the feel of the two-stroke snapping to attention or exploding out of a berm. A two-stroke may not find the traction like a four-stroke but it has other strengths that a four-stroke just can't match.
 | April 1, 2006 By:Eric Tabb
Since our last article the 525 has provided us with many miles of fun. The orange giant has taken us on numerous desert rides, over plenty of nasty singletrack, on a few dual-sport rides and even found its way onto a few motocross tracks. The 525 handled each of these scenarios remarkably well. This fact can be partially attributed to the extremely rider friendly and torquey motor, partially to a chassis that isn't overly stiff but can take a beating and partially to the Novation suspension that has proven to be so versatile in varying conditions and terrain we expose the bike to.
 | January 1, 2005 By:Eric Tabb
After spending quite a bit of time over the last year riding on technical single-track trails like Kennedy Meadows and Frazier Park in Southern California I found myself wishing for a bit lower gearing on the 525. Even though it is the EXC model with the low first-gear the bike does still require quite a bit of clutching through the rock sections. In addition once you clear the technical stuff the bike doesn't seem quite happy to lug along in third, instead it requires a bit of shifting between..
Untitled Document Off-Road Videos - Check out over ten years of extreme 4x4 action, product testing and the Off Road Nation at play. Baja racing to rock crawling, ATVs in the sand to motorcycles in the dirt, it's all here. Rate them, share them and upload your own.
ATV Reviews - Honda, Suzuki, Yamaha, Polaris, Kawasaki, Can-Am. First rides to long-term tests, check out the latest in ATVs, UTVs and Side-by-Side vehicles of every make and model. Read expert opinions and follow custom project vehicles. |
Axxxtion Sports..... Axxxtion Sports is heating things up with their 2010 Winter Heat snowmobile calendar! Simply Sexy! |
