Tech: Honda - Dirtbike at Off-Road.com
Dirtbike »
Price and Compare Vehicles:
New, Used, and Powersports    Go button
Tech: Honda
2010 Honda CRF450R
September 18, 2009
The Honda CRF450R has always been out in front. But now it?s WAY out in front. We took the best MX bike in the class for six years running and made it better in every way. Easier to ride.
Yoshimura Announces Camshaft Kit for CRF450R
September 18, 2009
R&D designed the CRF450R camshaft with a potent curve featuring BIG mid to top-end power and a ton of torque. This means that when you whack open the throttle, you'll get a big hit off the bottom and a huge boost in top end.
2010 Honda CRF250R Motorcycle
September 16, 2009
Abandoning the engine and chassis from the previous generation CRF250 gave them freedom to create a whole new fuel-injected Unicam® engine that utilizes new space- and weight-saving technologies that better integrate the powerplant into an entirely new Twin-Spar aluminum frame for optimum weight savings and mass centralization.
New Roost Guard From Yoshimura for CRF450R
August 12, 2009
The new Yoshimura Carbon Fiber Roost Guard not only protects the Honda's header from damage from rocks, dirt, mud and debris
Yoshimura Announces New RS4 for 2010 Honda CRF250
August 10, 2009
Yoshimura will be offering several different configurations of the RS4 for the 2010 CRF250 from a Stainless Slip-on to the factory Titanium Full System for ultimate racing performance.
Don't Ask: Super Hunky is At It Again
August 1, 2009
Rick Sieman answers your dirtbike questions on crank stuffers, silencers, glowing pipes and crud in your bowl. Or is it called "mung"?
More Coolant Capacity with Fluidyne Powersports Radiators
July 30, 2009
Replacement radiators for the new-generation, fuel-injected Honda CRF450R that feature 42 percent more fluid capacity, lower coolant temperatures and greater strength than stock, all with the convenience of direct-fit mounting.
Race Tech Develops Gold Valve Kit for Steering Damper
April 17, 2009
The CMGV 2001 Gold Valve Kit comes with a Gold Valve, Ultra-low friction piston band and instructions for 3 damping options: soft, standard and hard.
Yoshimura Powers Up the Honda CRF 50
April 16, 2009
Yoshimura has the answer for those wanting more for their Honda CRF50. Yoshimura's Bore Up Kit adds tons of torque and overall power everywhere by upping the displacement from 50cc all the way up to a whopping 88cc.
Untitled Document
Off-Road Videos -
ATV Reviews -
Axxxtion Sports.....
Enewsletters
Stay on Top of All the Action:
Sign up for Off-Road.com's Enewsletters
Click here
